It is currently Sun Oct 22, 2017 11:28 am
Post new topic Reply to topic  [ 8 posts ]
195.05 Points
Images: 12
Post Posted: Mon Mar 06, 2017 10:31 pm
I've got a 98' 175 with a 90spl Evinrude. I'm planning a rewrite and would like to replace my gauges while I'm at it. From what I understand I need to be careful on what tach I decide. Can anyone recommend a tach or what I need to look for?
2,633,261.45 Points
Post Posted: Tue Mar 07, 2017 12:04 am
Depends on if you have a separate system check gauge or if you want a tach with the system check built into it
195.05 Points
Images: 12
Post Posted: Tue Mar 07, 2017 12:06 pm
I'm looking to cost out replacement guages for what I currently have. My current tach doesn't appear to have the system check built in. I attached a pic of my console below (I think)
From Left To Right is my Tach, Volt meter, Fuel gauge, water psi, Trim
591
2,633,261.45 Points
Post Posted: Tue Mar 07, 2017 1:38 pm
Check with Marine Connection Liquidators in Ft Pierce. you can probably get a full set of NOS gauges for under $100.
I'm really surprised you don't have the system check with the four red indicator warning lights and alarm. Does your boat beep when you first turn on the key?
195.05 Points
Images: 12
Post Posted: Tue Mar 07, 2017 2:57 pm
Thank you, I sent them an email asking about the gauges/panel.
My boat does beep when I first turn the key. It also beeps if in gear when I got to start.
Post Posted: Tue Mar 07, 2017 9:13 pm
when i was there a few weeks ago they did have 1 of your panel left..
4,003,596.60 Points
Post Posted: Wed Mar 08, 2017 4:10 pm
Since you are in Venice, look at Marine Surplus in Sarasota by the Airport. They have a lot of stuff pretty decent prices. And they are local to you. They don't have any Aquasport plates however.
195.05 Points
Images: 12
Post Posted: Fri Mar 10, 2017 2:54 pm
Heard back for MCL, top notch service. I battered the poor guy with a bunch of quesitons, and he was patient and knowledgeable. He's got a panel to sell me ($135 for the panel and switches), and another $185 for the instrument cluster. I just need to verify some measurements.
Thanks all for the help!!!
Now I just need to message Bob on Facebook to work out the re-wire!!!!
- Ken
7,376,723 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group :: Style based on FI Subice by phpBBservice.nl :: All times are UTC - 5 hours [ DST ]
