It is currently Sun Oct 22, 2017 11:30 am
Post new topic Reply to topic  [ 3 posts ]
80.05 Points
Post Posted: Sat Mar 18, 2017 12:52 am
How do you replace this anode? Whats the trick? This is a 250 2 stroke.
2,633,261.45 Points
Post Posted: Sat Mar 18, 2017 10:28 pm
Should just be a single bolt under the cavitation plate.
Post Posted: Mon Mar 20, 2017 5:27 pm
yup you might need to turn the prop a little when pulling it off but 1 bolt is all that holds it. make sure you note the orientation of the fin before you remove it.
7,376,733 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group :: Style based on FI Subice by phpBBservice.nl :: All times are UTC - 5 hours [ DST ]
